Your Advanced variables look mostly okay (I’m assuming Sandy Loam soil). I wouldn’t increase your Crop Coefficient to 100%, but just leave it at at 75%.
Drip systems are a whole 'nother animal than normal spray heads (which aren’t that easy anyhow!). I honestly don’t know how Rachio calculates times with them (or CAN for that matter). There are so many other variables they have no knowledge of (how many emitters per plant, what size emitters, are plants jammed together, all irrigated, or spread out with dry ground sucking up the moisture, etc.). And while I have my own theories and methods, I’m probably not the best person to advise you on that. The only real unknown variable is the Nozzle Inches per Hour, but with Rachio’s Drip values going from 0.5"/hr to 2"/hr, and IMHO real systems varying more than that, it’s hard to nail down. But rest assured that is the ONE variable you need to try to get right.
If you have areas with grass, or even shrub or other type of crops but are watering the entire area (not using Drip systems), it becomes a lot easier, and I can help more with that. Even then, getting the Nozzle Inches per Hour is very important, yet most will just use the default values.
Enough about that, because I also SEE SOMETHING WRONG: Your digital moisture charts have a problem for YESTERDAY. The moisture level for each day (inches) is simply the previous day minus the Crop Evapotranspiration + Any Rain + Any Irrigation. For 5/9 the value is 0.88". 5/10 had no rain or irrigation, so subtract 5/10’s CE of 0.15" and it should be 0.73". But it’s NOT! It’s 0.24". I have no idea where that could have come from. Even Emptying a zone would take it to zero, not 0.24. So that math doesn’t work that day, but does every other day. Did anything funny happen yesterday? I’m guessing some Advanced or other settings were changed, and from my experience, Rachio can get confused when that happens (or I’m confused about what Rachio is doing, not sure which).
Anyhow, the chart shows the system will water 0.22" tomorrow (a correct amount, BTW, based on your Available Water, Soil Depth and Allowed Depletion), which it needs to, based on the new moisture levels. From what I see, it will probably water most days, skipping only 1 or 2 in a week. That’s not great, but your soil won’t hold much more water, so that makes it difficult. My Clay soil holds almost 3x what your soil does, so I can water much less often.
How about posting next week’s moisture graph and table?
