Flex allowed continued 0%
Ive had my system for years and flex has worked fine until this yesr. I set the weather source to the new network this year. At first it seemed fine but then I realized it was not watering at all. I switched to a local station that I’ve used in other years but for some reason it is allowing zones to remain at 0% for days on end. I have not changed the zone settings.
Are you sure you didn’t inadvertently disable that schedule, or remove this zone from the schedule?
Can you look at your calendar and see if it shows upcoming waterings?
Yes, I’m sure. I’ve been using thia for about 8 years. This is the first time ive seen this happen.
