I am restricted to only water once a week as per county regulations. I also have very sandy soil, so irrigation is recommended at 3/4” at a time.
I am new to rachio and it just skipped due to default rain skip threshold of .125”. So I know I need to tweak the settings for my fixed once a week schedule.
Since rain skip only looks +/- 24h, I assume I need this threshold to be pretty high to prevent skipping watering if a bit of rain comes in the day before or after. I’m targeting about 1” of water a week, maybe erring up to 1.5”/wk.
What is the recommended threshold settings for those that can only irrigate once a week on a fixed schedule?
Should I set rain skip to 1”? Or is that too aggressive? Since it won’t look at the other 5 days of the week, that would prevent watering if I’ve seen 1” recently, but otherwise add 3/4”.
Or should I disable rain skip, and instead let it just use saturation skip? Can you run saturation skip with rain skip disabled, and will saturation skip work well on a fixed schedule since it looks across the week unlike rain skip?
