- Master valve is now disabled during soak period of cycle/soak. Previously, master valve was enabled for entire schedule.
- Since last firmware patch, if power was lost and device came back with no WiFi, would not be able to run schedule. If WiFi was lost (no power cycle), schedule was running correctly.
Just a clarification on #2. Is this condition now fixed or are you noting a current issue?
Sorry for the confusion, both of these items were fixed today.
Is it possible for an end-user to determine if this update has been successfully installed?
Currently no. If you want to be super safe, a power cycle will always get latest firmware…but you should not have to do that. Firmware is pulled down by the device as soon as it is deployed.
Thank you.
Best regards,
Bill
