I’ve been running my trees on drip lines with a Flex schedule for years. Recently we had some new trees planted, alongside the established ones. The Flex schedule of course is very deep watering, but with days between watering. The new trees wouldn’t survive, so I put them on a fixed schedule. Understandably the Flex might not fire as often, if at all, but if it did I would expect it to run for the same amount of time, which was 340 mins. Today I saw a notification that FLEX ran, but for 40 minutes, which happens to be the same amount of time that the fixed schedule runs for the same set of trees. I wonder if that’s a reporting bug.
Here is the FLEX schedule showing 340 minute run time:
These are the three schedules associated with the trees:
Here’s the history, reporting that both schedules fired at the same time and for the same amount of time:
Finally, here’s the Flex moisture table that doesn’t indicate Flex actually ran at all:
Please advise, and thanks!
