Putting in new beds in the yard; needed to see the heads to observe coverage area, running for 2 minutes.
Appears the flex schedule has now adjusted for those zones,even though they didn’t get adequate run time.
Is this by design ? Are there parameters that can be adjusted to avoid this when testing the system?
Yes, they would adjust with flex. It would assume 2 minutes of water was added - which it was added. If that was enough to push watering out, it would push it. If not, it would water the next day (although possibly 2 minutes less).
