Deleting Removed Hub
What’s going to happen if I deleted valves and hubs from the app without holding the buttons down as the app said I must?
While troubleshooting hose timers, I switched to a spare hub. So then there were two hubs on the app’s Home screen.
After troubleshooting, I wanted to deleted the valves from the disconnected hub, and then delete the hub. In the deletion process the app said I MUST hold down the buttons for a number of seconds, with a checkbox to swear that I had. Not wanting to connect the hub just to remove it again, I lied, checked the boxes, and deleted the valves and the hub.
Is anything bad going to happen?
