Delay time Between zones
Since my water tank don’t have capacity to a complete cycle, I need to have some delay between zones in order to allow the tank to refills
Is any suggestions ?
See if this support article applies to your situation
You then may have to set up cycle and soak for each schedule you have.
Thank you I will take a look
The issue with the soak cycle, is that it still keep using water
Hello
I got but I don’t want to wire the pump to the controller.
Just a software set up to delay between zones !!
Thank you once again for your support
I think even if you don’t connect the controller to the pump, it’ll still work. “Well or pump start relay” means you are telling Rachio you have a well and you should be good to go without any new connections. I don’t know since I don’t have a well. Try it out and experiment to make sure things work as you expect. Take another look at cycle and soak settings since the well delay is added there.
Or instead of a delay I could run several daily cycles !!
