Is anyone having issues with the Crop Evapotranspiration values for the future? I am showing a “0” value. Since ET drives the irrigation, I am also showing no future irrigations.
I’m having the same problem. Weather forecast shows as zero F. I was thinking it was an issue with my PWS, but seeing your post confirms it is a Rachio issue.
I find this tool very helpful. Whenever there is a heatwave or rain in the forecast, I always double check to make sure RACHIO see the same.
Same problem here. Must have just happened at Rachio. Needs to be fixed shortly for Flex Daily to work right. Although looks like it will save a lot of water.
