Crop Coeficiente Increase %
Hi Folks, after reading on this forum my understanding is that I can increase/decrease crop coefficient by 10% to adjust flex schedule in case needed.
My question is: increasing by 10% means (for example) from 60% to 70% (adding 10%) or in the same example from 60% to 66% (increasing by 10%).
Can you confirm what is the right way to adjust the parameter?
Patricio
It’s all guesswork at this point. If you really want to add 10% more water week after week, then multiply the current Crop Coefficient by 1.1 (so 60% would go to 66%). But changing it from 60% to 70% increases the water by 70/60 = 16.7%, which isn’t huge. As I said, when you’re modifying the water output, it’s all guesswork. Changing 10-15% of the value seems like a step worth trying, and one that you should be able to see a difference with. Which is what you’re after.
