My system is fed from two different main line sources so I have two master valves. Can the Rachio 3 handle multiple master valves? Ideally separately, but if I tied the two MV together so that when a zone goes on, essentially 3 valves open ( 2 MV + 1 Zone valve) I have total of 14 zones.
Does the Rachio 3 give any push notice of power failure, WIFI loss?
In the event of WIFI loss does it still water based upon original zone settings?
Any kind of notice of bad solenoids or wiring? perhaps amperage readings (I currently get that)
(I’m replacing my current smart controller that on the surface appears to offer more features than Rachio…at least I haven’t seen anything on the website)…Thank you
