Compatibility with Orbit valves?
Hi,
I was wondering if the Orbit valves (https://www.orbitonline.com/product/inline-sprinkler-valve/) are compatible with Rachio?
I was pretty sure they are, but I started worrying about those maybe being 24 DC instead of AC ?? I can’t find the info anywhere!
So anyone using the orbit valves with Rachio?
@magimat - those should be 24 VAC and should work just fine with Rachio.
The Home Depot page says - “Standard Voltage: Designed for use with all 24-volt systems.” since most systems are 24 VAC I’m saying they should work fine.
I had an Orbit controller and valves for 10 yrs and just upgraded to the Rachio 3e about 2 weeks ago and the Rachio runs them fine.
thanks!
Your welcome!!
