Hello, It is time to change my watering clock. I tried this morning and even though I can get to the screen, upon setting the new time nothing gets updated or sent to my controller. All other setting changes are working OK. I have a Rachio 3 using iOS 14.1 .
Even when you do it from app.rach.io ? Even when you tried from another device such as your desktop or laptop computer?
From app.rach.io , select the schedule, click Times, click Start at specific time, click start hour, click start minute, click OK, click Done. You should see an Updating Schedule mesaage.
Using the cloud app works ok. The problem is with the phone App. It has to do then with the latest apple iOS 14.0.1. Please fix the phone app. The beauty of Rachio is that it exist on your phone.
I’m running this on iOS 14.0.1 with the latest version in the App Store. Here’s a recording of what I see when changing a schedule’s start time. In this case, changing from “Start after Sunset” to running at 6pm.
My problem seems to be only whe using start at a specific time. I get the rolling numbers to set the clock and the AM and PM, but upon clicking DONE, it does show the UPDATING screen. The window closes and turns gray. If I tap it again then I am back to square one.
I’m wondering now if it’s a miscalculation with the keyboard maybe.
When you’re changing the time, are you using the keyboard, or does the keyboard appear while changing the time? Or are you scrolling the time into position?
Also, if you don’t mind sharing, what device are you using? That may help me debug it
I was thinking phone device, maybe there was a layout issue with one phone model, but looks like we have the same or at least similar phone. So I don’t think that’s the issue.
When you tap done from that screen, it shows “updating…” then just goes into a gray screen? Do you see anything else when it’s that gray screen or is it just gray and nothing else is there?
Same problem here. iPhone 12, trying to setup a simple 3rd schedule where I can have the 2 front lawn sprinklers go on for 1 minute each at 1:00 am. I go to e yet the time and it grays out like op and defaults to before sunrise
