Cannot delete a zone
How can I permanently delete a zone. I have tried the ‘tap once’ and slide the disable button and grayed out the zone as described in other posts but it is not removed from the schedule which is causing issues with that zone as I have another zone defined for the same solenoid. Any help with this issue would be greatly appreciated.
You cannot delete a zone per se. You can rename it and disable it if you want, but that doesn’t change the fact that the “zone” exists as far as a controller output. Manually remove it from the schedules it is in, then disable it?
