Can i use 24v DC valves with Rachio 3?
I currently have these valves, will these work? they are 24v DC. I see that Rachio 3 wants 24vAC…
I have not tried using 24VDC and as you said Rachio (I would say most, if not all, sprinkler controllers and valves) are 24VAC. I have heard that people have problems when running 24VDC on a 24VAC system directly and really would not recommend it.
@Gripex - NO.
Even if it were the correct current, the power draw on those is going to be too much for Rachio to handle.
It’s Correct :white_check_mark:
