Best Ambient Weather Network | How It Works and Why You Should Use It
I researched the best Ambient Weather Network for the past few days because I want to start tracking accurate weather conditions around my home. I read reviews on several websites and tech blogs, and they are marking these two as the best options:
Ambient Weather WS-2000
https://www.amazon.com/Ambient-Weather-WS-2000-Station-Monitoring/dp/B07GRBY9NP/?th=1
Ambient Weather WS-2902
https://www.amazon.com/Ambient-Weather-WiFi-Station/dp/B01N5TEHLI/?th=1
However, I am still confused about which one would be better for my needs. I want real-time updates on temperature, humidity, wind speed, rainfall, and lightning alerts. I also want a station that connects smoothly to the Ambient Weather Network so I can monitor everything from my phone.If anyone has experience using either of these models or knows which one works best with the Ambient Weather Network, please share your advice. Any recommendations would be appreciated.thanks in advance
I have the Ambient Weather WS-2902C and it meets my needs. I have it connected to both the Ambient Weather network and the Weather Underground. From my phone or desktop, I can see the dashboard of all the collected information. I’m located just east of Tampa, FL.
I configured the Rachio 3 controller to just use my particular station, but it appears that the projected weather is still picked up. Is it configured correctly, can’t guarantee it. I also set the thresholds maybe too high. I have had my sprinklers go off when it had been raining and the 2902C said I’d received 1” of rain (Rachio set for 3/4”).
For the rain cup, I’ve experienced birds perched on the side and using the cup as their restroom. It caused the rain to stop recording (and this happened during hurricane a couple of years ago). I’ve since added better spikes and no more problems..
I mounted the weather station on a 10’ piece of conduit and attached it to the side of my pool cage. Ground to station is approximately 25’.
Good question
I have mine pointed at my 2909 station also. I still get rain skips when no local rain and watering when it’s received over the set amt locally
I havent found an ignore regional weather switch
