Arizona: Fixed Schedule Programming
Take a picture of the top and bottom. Usually they are color coded…If only the industry were smart, they would make a uniform color coding system, but each manufacturer has their own…
So since you have those, chances are depending on what the GPH is on them, and how many you have going to each plant, your PR (inches per hour) setting will most likely be .25" - .50".
