I’m attempting to leverage the public API, but the API is continually returning this error:
{"errors":[{"message":"The client is not authorized."}]}
I’m sending this command (with my API token – not the one displayed below):
curl -X GET -H "Authorization:Bearer 8e600a4c-0027-4a9a-9bda-dc8d5c90350d" https://api.rach.io/1/public/person/24763e8a-4418-11e4-a183-164230d1df6
Any idea what might be causing this?
On another note, the “Public API support forum” link on this page https://rachio.readme.io/v1.0/docs is returning this: “Oops! That page doesn’t exist or is private.”
Sorry, upon reviewing your post a second time, I noticed you did clarify that you are using your own API token, I’ll leave it up to Rachio team to troubleshoot this issue.
wow, API is only valid as long as the user is logged in? Does it time out due to inactivity?
I was considering to add rain delay support via Rachio’s API to wufyi so that if rain is detected, but we are not yet sure about validity of the data reported by the weather underground, wufyi would activate a temporary rain delay until the data is verified and rain delay can be disabled if precipitation data was deemed to be false.
If users will have to constantly update their API tokens, noone will end up using it.
Is there a way to obtain a persistent API tokens?
Edit: I’ve just logged out, and back in (via https://app.rach.io/), my API token did not change. How long does the user have to be logged out for, before the token is invalidated?
Interestingly, the key you PM’ed me also didn’t work. I’m sending the cURL command via Terminal on macOS 10.12.5. Using the new key you sent resulted in the same error. Might there be something else going on here?
Also, thoughts on Gene’s question? Do tokens/keys expire at logout or after a period of time?
Can you share your complete URL command? Use demo API of course.
Never mind, I really need to pay more attention. I’m sure you are using it exactly like in the example.
Have you tried “–header” instead of “-H”, not sure if it would make a difference, but…
Edit: After reading mac’s documentation on curl, “–header” should not make a difference. It did mention something about possibility of additional headers, but I didn’t get too deep into it.
Is one API token only authorized to access one person_ID, or can multiple stations (persons) be managed using one API token as long as their person_IDs are known?
For example: Lets say I want to add a rain delay feature to wufyi.com. Do I need to know each person’s API tokens or just their Person IDs? It seems I need their API token just to look up their personal ID, but can I ever use anything other than their API token to interact with their personal ID?
@franz Can you elaborate more on the cloud logout? How long can API tokens be expected to remain valid?
If the API token provided by the user is suddenly invalidated (expired), is there a way to get an updated token without bothering the user?
