API call starts a manual schedule that runs daily
I’m using the API to call public/zone/:id/start to open a valve on demand and run it for an hour. It works fine, but the valve opens for another hour without an API call after about a day. It’s recorded in the watering log but I haven’t made an API call.
I’m using an ISY from Global Devices to issue the call. I’m 98% sure the ISY isn’t sending it so I’m wondering if this is somehow designed behavior for the Rachio.
Scott
@slucas
There wouldn’t be any correlation as those runs are just “one” time.
Are you sure some other automated process made a similar call or maybe a test schedule that was created?
If you experience this again I can have the development team do a quick review.
Have a great day!
Franz, thanks for the reply. I thought that’s how it worked, your confirmation helped me narrow down the problem.
I’m doing some packet capture now to see if the ISY is issuing the api request. I should know in a day or two where this is coming from.
Best,
Scott
