I’m replacing a Hunter Pro-C controller with a Rachio Gen 2. The Hunter already has an Orbit Model RX-2 wireless sensor. I have read that the Gen 3 supports 24v, but I have a Gen 2. I also read that Gen 2 will support Orbit wireless sensors, just not sure if the RX-2 is one of them. Looking in my controller, I see that the Orbit controller has 2 red, a white, yellow and green wire. Only the red ones are connected to the 24v connections. I’m reading the following article:
Gene, thanks for the response. What do you mean by “Remember to turn on the Rain sensor on S1 terminal (in case you do end up using S1 as per diagram).”? Do you mean “connect the yellow to S1”?
