@AthenaIt is not yet accessible. Microsoft intends to quickly update Windows 11 to include Android version 13. It might be accessible.
Currently, I’m utilizing Bluestacks 5. It’s a Windows version of the Android emulator. You can access and use all of your Android apps, and it works well with Windows 10 and 11. Additionally, I saw that they have Bluestacks 10, which I haven’t yet tried.
Give it a try.
FYI, I just just opened Bluestacks today and received an alert, this is because I recently upgraded to a new version of Win 11. If you get an error like this (You need to enable Hyper-V) follow the below link to enable it, it’s pretty easy.
Heads up I tried everything on the above link to enable Hyper V and it did not work. At the end of the document it suggests to open a command prompt and run the script. I tried this and it did not work, finally at the bottom of the page it tells you to run the app with Admin rights, by right clicking on it and selecting Run as an Administrator and this worked. I also right clicked on the shortcut and selected Properties and clicked on Advanced and set it to always open with Admin rights.
It will look like this on Win 11
