I had 5 zones and converted one zone to a spigot. Is there a way I can set up a schedule where it’s on most the day. Or constant on?
The controller cannot have more than one zone at a time nor leave one on all the time. You can, however, disconnect the hot wire from the controller for that zone and manually turn the valve on with a 1/4 turn of the solenoid.
Sometimes I get caught up in the tech. Trying to figure this out I had that aha moment. So I just removed the diaphragm from the valve.
I probably would rather turn the solenoid instead of taking parts out to prevent them from getting lost, but up to you and that works well.
