It would seem my system has changed recently and so I need to get in and tweak some advanced settings and understand their impact a little more.
Firstly I have 6 zones all under one Flex. They are all low pressure Rainbird XFS drip lines with perennials. This post here is fantastic at explaining their water pattern and helped a lot: Drip math? - #16 by MarkSanDiego But I still have some specific questions.
@MarkSanDiego seemed to imply about all the changes that are required for more frequent watering with this type of system vs what Rachio is doing. I believe I have the opposite problem. My system is watering daily because it doesn’t think it ever gets the moisture level high enough. Here is one of the zones:
(this is all in cm not in by the way)
It was showing historically 0.06 per day of irrigation, and then nozzle cm/hr was 1.29. I bumped it to 2cm this morning and you can see in the graph it’s gone to .09 per day of irrigation. You’ll notice one of the oddities is it thinks it’s going to water over 2 cm of water “tomorrow” but that never happens. I’m pretty sure every day it shows the next day with a large amount, and then historically it’s always 0.06.
This is one of the zones, they are all pretty similar, with the only difference being the amount of light they get. It’s all default, except for the nozzle cm/hr which I changed today.
When I first made the Schedule, it suggested running each zone for 3 mins. That made no sense. I bumped it to 40 minutes as that’s about what I would think would be a good starting point based on previous experience. Overall, this drip setup should be longer waterings less frequently, but that’s not what’s happening.
I’m looking for advice on what settings to change such that it calculates more water after an irrigation.
