Adding WUnderground Station to Rachio with Gen 2
Hi @Gene, can you add this weather station please?
IDESSA16
https://www.wunderground.com/dashboard/pws/IDESSA16
thanks
Hi @Gene. I also have a Weatherflow Tempest station. Added to WU. If possible, can you add my WU URL as well? https://www.wunderground.com/dashboard/pws/KSCFORTM135
Thanks in advance!
Hi @Gene, would you mind adding me to the list of new Tempest users with a Gen2, please?
https://www.wunderground.com/dashboard/pws/KNCRALEI657
Many thanks in advance - this thread saves me from becoming suicidal after a new tech purchase :slight_smile: . Really appreaciate your help for us all.
Hi @Gene, would you mind adding my Tempest so I can use it with my Gen2, please? https://www.wunderground.com/dashboard/pws/IREGIN35
Thanks in advance!
Hi @Gene, I would like to ask you to add my Bresser 5 in 1 so I can use it with my Gen2.
I have added the station to Weather Underground and here is the link: https://www.wunderground.com/member/devices. I have tried to add the link to PWSweather myself but PWS says that the station is inactive.
Thank you in advance for all your help.
@ShauneS sorry for replying to your post but I did not find a solution to post a kind request for @Gene. Sorry for this and thank you for understanding. I am new on this Community.
Hi @Gene - I’m not sure which forum to use…I posted this is the older forum as well.
I have a new station that is across the street from me and closer. I see your site is still down…could you add this WU Station?
KFLPORTO122
https://www.wunderground.com/dashboard/pws/KFLPORTO122
Thanks in advance sir!
Sorry, pwsweather has changed their site and my autogeneration code is no longer working until I’ll update it. If you wish, you can create a pwsweather station to host the WU data and I’ll setup updates for that station. Simply create a station (register / follow the prompts at pwsweather) and send me the station ID and API key and I’ll take care of the rest. Alternatevly you can wait a few days for me to update and test the code which will allow me to generate a random station to host your data.
Thank you for understanding.
Gene, how would I add the station to my Gen 2:
https://www.wunderground.com/dashboard/pws/KTXCYPRE485
@hayou, you’ll need to have your data available to pws weather network in order for your Gen 2 Rachio to make use of it. I see that you have an ambient weather station, as they have a good native support for a pwsweather network so I recommend you use their native integration, which can be setup here: https://ambientweather.net/devices.
Step one would be to register at pwsweather.com site (which is free) and create your station (station ID can be anything you want, doesn’t have to match WU id). After you create the station, note the API key that they assign your new station (click edit next to the station name if you can’t see it).
Within ambient device screen (linked to earlier), you can click on pwsweather icon and specify the station ID within the left (first) field & station’s API key within the right (second) field. Click Connect and you should be all set.
Once your new station starts getting updates, it should show up within Rachio map sometime between 4 and 7 days, after it passes pwsweather’s internal QC process.
If you run into any issues, don’t hesitate to ask. I can always keep your pwsweather station updated in case native integration fails work.
Hi @Gene,
I have rachio 3e should I have to use the same WA as rachio2 ? I couldnt find my WU wether station on the app list.
In case the answer is yes would you help me to forward the data from WU to PWS ?
My WU station:
KEY:redacted
https://www.wunderground.com/dashboard/pws/IRASTI1
My new PWS station:
API key: redacted
Station ID: IRASTI1
Thanks!!!
Yes, 3e lacks WI+ support, thus it uses pwsweather network as far as I know (please correct me if I’m wrong). I’ve added your station to my app to keep updated. It should show up within a week on a Rachio map. Let me know if it does not.
Cheers,
Gene
Would it be possible to add this one to PWS Weather?
https://www.wunderground.com/weather/us/fl/punta-gorda/KFLPUNTA222
@Gene Appreciation if you could add KKYLOUIS469 to PWS. Thank you!
https://www.wunderground.com/dashboard/pws/KKYLOUIS469
Hi Gene,
Would you please add
https://www.wunderground.com/dashboard/pws/KCAESCON360?cm_ven=localwx_pwsdash
to the PWSWeather network?
@Gene
Gene could you please add https://www.wunderground.com/dashboard/pws/KCOLITTL773
Thank you
@Gene
Can you also add the following station to Rachio?
https://www.wunderground.com/dashboard/pws/IVANCO26
Thanks in advance!
Hi @Gene,
I would really appreciate if you could add these 3 stations:
Thank you!
Hi @Gene, could you please add my weather underground station too? Thanks for very much for this! https://www.wunderground.com/dashboard/pws/KALMADIS257
@Gene can you please add my PWS: KTXSANAN2057 (wunderground)
@Gene Will you please add me as well if it is still possible?
Weather Underground Station: KNJWYCKO24
Very much appreciated.
