There needs to be an area where owners can note where each valve located through out the property.
Have you tried the yard map feature?
Great idea, I have multiple valve boxes with multiple valves in each box.
Personally, I think you need a drawing of the yard with details like where the water lines are run, with dimensions from landmarks in the yard. This is more than Iād expect in the app.
I only saw the ability to draw the zone in drop heads. It would be nice to support KML files and ability to drop where the valves are and maybe even where the lines are ran.
Yes. Yard map only allows you to map each zone coverage. There is no place to not valve location. A separate part of yard map should be to place the valve location. That way, when needing to show. Repairman, we could email it to them.
