It got hot enough today to trigger an IFTTT watering of my potted plants. Strange thing, though. The watering is set for 1 minute for each of the pot zones. The watering history shows “Watering Zone 4 Garage pots for 1 minutes” followed by “Watered Zone 4 Garage pots for 51 seconds” (Same repeated for the other two zones.)
I believe the Iro clock as some daily drift, it’s probably that. If you power cycle the time should be closer to one minute. Believe it’s a display issue.
Tracked this down to water hammer enabled on your device. Looks like we record the duration when water hammer starts (~10 seconds before next zone). The two zones overlap and then the first one shuts down. Display only issue, will fix in a future firmware release. Thanks for reporting this!
Thanks for the explanation. I guess I did not see this on the normal schedule for the pot watering because those run times were all more than a minute.
