I have hunter MP rotator sprinkler heads in my yard.
The sprinkler choice I am using does not seem to provide adequate watering times.
What sprinkler type should I use when configuring my zones to fit this sprinkler type
You can use the rotor setting, but a better option is to use advanced settings and set up a customized sprinkler. Look at the precipitation rate on Hunters website for MP Rotators.
Like @robertokc said…
I have the same. I have it set up as a rotary nozzle, which by default is not accurate, but with any of the nozzle choices, you can adjust the PR (inches per hour) in the advanced settings. Typically, MP Rotators have a PR of around .45-.50" per hour.
