is there a way to see what the new values are? I manually changed them, but now would like to correct them.
Maybe a better explanation…
At the beginning of May, I got a notification that my duration times were being changed (extended) for a seasonal shift. I thought it told me what the new values for each zone would be. A few days later I went in and manually lowered some of the durations. Now I would like to set them back to the seasonal shift values (the ones that were set automatically at the start of May). But I can’t find what the new values were set to. In the app, it just shows a seasonal change was made, but no values. Where can I find those?
Thannks
Hey @alfredoj-
You should be able to see how the time was adjusted in the email you received on the first! Do you have the seasonal shift email notification enabled?
McKynzee
Yes, you are correct. I just found it! THANKS!
And yes, I do have seasonal shift enabled.
In April, this schedule ran for 1 hour 29 minutes. In May, this schedule will run for 1 hour 50 minutes.
Back yard by Swing set no significant change in minutes
Behind Garage no significant change in minutes
Back yard by Deck has been adjusted from 13 minutes to 16 minutes
Front Parkway has been adjusted from 13 minutes to 16 minutes
Front East has been adjusted from 13 minutes to 16 minutes
Front West has been adjusted from 13 minutes to 16 minutes
Front Flower bed / west side of house has been adjusted from 11 minutes to 13 minutes
Back Flower beds has been adjusted from 10 minutes to 12 minutes
Driveway beds has been adjusted from 10 minutes to 12 minutes
