The web site does NOT specify 240v vs. 120v.
A Customer Rep responded 240v and 24 v output.
That is quite unusual for a sprinkler controller.
Why is 240v used here? It is expensive to bring that service to where the unit will be mounted.
Located in Miami Beach, Fl.
franz
2
@tweiss4208 Where are you seeing that requirement? We require a standard 120V.
DLane
3
@tweis4208 - what @Franz said. Here’s the proof:
Power Requirements
The Rachio controller must be connected to the AC power adapter included. DC Transformers are not supported.
Power Supply: External Transformer
(6-ft cord - 2.5mm x 5.5mm Female barrel plug)
Transformer input: 120 VAC ~60Hz 300mA
Transformer output: 24 VAC 1000mA
Zone output (24 VAC): Compatible with 24VAC Solenoids
