I just installed my new rachio3 with no problems except when I attempt to set up the zones . Zone one went ok no problem. When I advanced to zone 2 to run the test, Zone 1 came back on. The same occurred with zones 3 and 4. Any suggestions?
@ghstrobel1 - post a picture of the Rachio wiring - please - to verify it is wired correctly.
I’ve seen this before where one will for get to skip the first terminal which the Master valve. Any zone you run, will turn on zone 1 since it is probably wired there. Check the wiring and move everything over 1 spot to the right.
