Excuse me if this has been covered before … I’ve found out where to do this on the mobile version but is there a place on the browser version to edit\delete a custom nozzle?
I’ve also noticed that on the mobile version (android 4.4.4) the custom nozzle has an option for “Flow Rate” (without a defined unit) while the mobile version has an option for ‘PRECIP’. Shouldn’t these inputs be the same, or at least give an option for both types?
Hi @ronjonp
You’re correct about the web version not having the option to edit/delete a custom nozzle. That’s planned functionality, but hasn’t yet made it into the app. As far as the discrepancy between “Flow Rate”/“PRECIP”, we’ll look into this and get sync’d up on our terminology…
Thanks for the reply Dan .
What about the flow unit? Does this change to GPH\LPH if an emitter ‘nozzle’ is selected or is it always GPM\LPM? IMO the option to be able to input these values (mobile & desktop) as either precip rate or total flow would be helpful.
