Is there a way to manually ask Rachio 3 to read the values from the flow meter?
I was able to test the leak detection using the “Inactive Flow Check” feature and manually turning on a valve while the controller was triggering it.
Now I got a “Flow detected when no zones…” notification indicating that I may have a leak but I did not get any notification when I manually shut the valve off.
Therefore I’d like to manually monitor the flow to see if the leak is still going on.
I’m kind of able to workaround that by using a zone that is not plugged in and run the calibration on this zone, but that sounds kind of a hack.
Thanks,
François
I agree this would be a simple and nice feature to have. Just show flow rate per flowmeter.
Me too.
I’ve asked before. A simple historical list of flows would be nice too.
