Says 1 day when it’s programmed for 10. Should I worry it’ll irrigate everyday?
Thanks
Thanks
I would double check on the mobile app to see if it has a different value. I will have @Dan verify this issue and implement a fix. The mobile app will have the correct value and display.
Thanks for reporting it!
This should be fixed.
@tigre, you’ll need to re-save the schedule and may need to refresh the app your browser. Let me know if you run into any further issues…
Happy New Year!
Dan
@tigre, just wanted to check in and make sure your schedules are working properly?
Let us know if you need any more help and/or need anything double checked.
Best, Emil
