Hi. I have a Rachio 3 unit installed with a Pump Start Relay using a well pump, which is working fine when I test it manually. I have 4 zones, and when selecting the “Quick Run” option, each zone cycles accordingly one by one by just pressing start on whatever zone I select. The problem is when Flex Monthly or Flex Daily Schedule, the zones doesn’t change and irrigates the same one by not cycling to each other until the selected time ends.
How do I fix this? Also, is it possible to assign the specific zones when I don’t have any low voltage wires coming up from the pump zones due to the zones just cycle by turning on and off each one? At least it will help if Rachio just cycle through them which are pretty much similar in size .
Thank you all.
