I skipped the zone wizard when I was first setting up as I was in a rush. Now I can’t seem to find a way to do it from the app. Do I have to reset and do the setup again? Hopefully not…
@Gr8ferozious On your dashboard, Scroll down to the “My Yard” card. On the bottom of that card, you will see a gear that says “Set Up Zones.” Click on that and it will run you back through that same wizard! Hope that helps.
McKynzee
Thanks!! Duh🙄 I should’ve figured that out.
