I recently installed a g2 and am very satisfied. My current 4 zones run via a master valve. I would like to add 2 zones and bypass the master valve. Can i configure the controller to run both the master valve and 2 other zones?
The app can not run two zones at once in a schedule but we have had users wire two zones into “one” zone. The controller can run two zones and a master valve. If you do chose to do this do not enable water hammer feature as that would also run an additional zone.
I do not want to run multiple zones at the same time. I want to add 2 zones but not have them behind the existing master valve.
If you can have the master valve “on” when the 2 new zones are running you should be fine. We do not support turning “on”/“off” the master valve for individual zones.
