I’ve noticed that my lift master garage door opener doesn’t work as well when using the homelink or the lift master remote. I had a similar problem when I used led bulbs in the opener. Anyone else have similar issues?
Led bulbs is a weird one, the don’t generate a strong field. now if you were using a compact fluorescent, that would make a lot of sense, they generate a pretty intense field.
The LED thing is real… http://www.phoenixazgaragedoorrepair.com/garage-door-repair/1786/how-led-lights-can-cause-problems-with-your-garage-door-opener/garage-door-blog/
They broadcast interference in the same spectrum as the opener remote. This should not hold for wifi interference.
My apple airport was the cause for some reason. Moved it and it works fine.
