I discovered my personal oversight after rebooting my wifi, I didn’t think about the sprinkler. Turns out Iro does not automatically reconnect after an outage, at least mine did not. Next morning was a scheduled water date, but system wasn’t running. a glance at my phone told me system offline. a quick power power cycle fixed the job.
Is it possible to update to allow automatic reconnection?
@brm51 The Iro should reconnect. If you don’t mind, would you send us an email at support@rach.io with your serial number (found in Iro Settings) and the make and model of your router?
My log shows a wifi reconnect every day, 24 hours and 25 minutes apart. Is this programmed to disconnect from wifi and reconnect on a daily basis? The cadence seems curious.
The device should try to reconnect itself after falling offline. Are you using gen 1 controllers or gen 2? Any chance that the 24 disconnect is happening when a schedule starts? This could be caused by a zone fault…
