What should we be using with our Rachio 3? Which is more accurate? West suburbs of Chicago.
Thanks
I typically recommend using a PWS if you can find one on the map that looks accurate and has been online for a good amount of time. PWS are typically more accurate (if close by) and the data is more timely (minutes versus ~ a few hours).
Stick with PWS. WI+ is for people with no local PWS nearby. I’ve found that WI+ is very inaccurate also… However, I wish we could use OTHER weather stations besides Weather Underground. @franz any update to allowing us to use Weatherflow Smart Weather Stations?
No current plans on integrating Weatherflow stations.
Bummer.
Thanks
My neighbor has a Weatherflow station, and it shows up on Weather Underground.
