Why multiple zones not running together with qick run?
As stated above, depending on the length and size of your service line pulling too much flow really drops pressure. For simplicity sake we’ll assume you have 100’ of 5/8" type k copper feeding your system. 7 GPM yields a loss of ~12.5 psi. If you run another zone concurrently with the same flow 7+7 gpm through that same service line has a loss of ~45 psi!
