I used to check the hydration levels of the zones and the history but now I can’t find it. Was it removed?
Perhaps you switched from the Flex Daily schedule (which shows moisture percent in each zone) to either Flex Monthly or Fixed schedules, which dont?
ahe so you only see hydration levels in only one mode, that stinks i think you should see hydration in all modes so you are informed
Only by using Flex Daily is Rachio assured that all available information has been entered, because you’re depending on that information to control the moisture. If it was available in other modes, what would they do about it? If they thought the lawn was dry, they’d want to water it, but you’ve set up scheduling that doesn’t. And vice versa. Flex Daily is the only one that actually uses the moisture data, so it’s the only one that shows it.
That’s my (non-Rachio) take on it, anyhow.
