Usually about 10pm the night before I need to mow the grass I check the app and see if a cycle is scheduled for the following morning…want to make sure the grass is not wet when I need to mow…so at 10pm it said no cycle was scheduled…only when I wake up I find that sometime after 10pm it decided to run a cycle. Is there a certain time when it checks to see if a cycle needs to run? I rather not set a water delay, but guess I may have to?
What schedule type(s) are you running?
It is a Flex Daily schedule.
We determine if flex daily will run 12 hours and then 1 hour before the scheduled start time.
Thank you!
