Is there a way to re-purpose an old rachio for indoor use?
Suppose I just want to do manual schedule to put some water into some pots for plants?
Does this make sense?
I have a hose outlet in a “summer room”
What would I need to set this up?
And instead of sprinklers how would I get water into pots for plants.
Or is this completely not the way to do this?
Why not.
Start ghetto. Buy a valve from Home Depot, glue a spill cock receptacle to it. Connect a drip tube to it, bingo bango. You probably don’t want to use a flex schedule.
What might be fun to simulate flex, have an emitter drip into a rain sensor so that a schedule that runs everyday,will,be skipped until the sensor dries out.
I’ll try to post links to products later.
Rain Bird SW20-30PS Drip Irrigation Spot Watering Dripper/Emitter, 2.0 Gallon Per Hour, 30-Pack. This robust pressure-compensating emitter provides a medium-high 2.0 gallon-per-hour flow rate. Ideal f ...
$9.70
That will get you started in the think tank.
Oops, should have posted instead of edit. All of that can be purchased at Home Depot.
Should be a fun project to ease into.
franz
March 10, 2016, 1:48am
4
Or it can be used with a kegerator
This is what our hardware guru used for parts:
@plainsane Awesome thanks!
Do you mean Spill cock? or sillcock from amazon?
sillcockenter link description here
Hahahaha yea, spellcheck to the rescue, am I right?
