Watering was skipped with “Water the lawn skipped due to activated rain sensor” but I physically disconnected the rain sensor wires from the controller and in Device Settings -> Advanced I deselected Connected Rain Sensor. Is there anything else that I need to do to disconnect the sensor?
@rainfox, we apologize for any inconvenience. This is a known defect. If you power cycle the Iro, it should resolve the issue you’re experiencing.
Let us know if this does the trick!
Best, Emil
There is an outstanding defect in the firmware regarding updating the rain sensor setting.
If you power cycle the Iro the setting (enabled /disabled) will take effect.
We will be fixing the defect in an upcoming firmware patch.
Sorry for the confusion.
Thanks, that took care of it.
Just a followup, this defect is now fixed.
