I have a drip system schedule that is behaving strangely.
The schedule has 3 zones, Zone 4 set to 5 minutes, Zone 7 set to 1 munute, and Zone 8 set to 3 minutes. Water budgeting and weather intelligence are off.
This morning’s run shows that Zone 4 ran for 7 minutes, Zone 7 for 1 minute, and Zone 8 for 4 minutes.
This is behaving as if weather intelligence is set, but it is not.
I reviewed your schedule and the seasonal adjustment dial is set to +49%.
If you reset that back to 0% everything should run as you have the exact minutes defined.
I also noticed our Webapp does not show the adjustment dial, only mobile (iOS/Android). For our Spring release that dial is going away being replaced with a much easier way to adjust total minutes +/-.
