I have a new rachio 3. When one zone start it continue watering when the second start and the same with the others.
@nlarrain - is the reduce water hammer option enabled in the app? The reduce water hammer option opens the next valve in sequence before closing the previous valve.
@nlarrain Sounds like your zone one is stuck open and needs a rebuild.
I’m sure you’ve figured it out by now.
