Using same wire for 2 zones
I have Rachio and adding another zone for my vegetable garden. After adding the valves, I found out only one wire works and other one is broken. Now I have to dig to replace the wires, but can I try connecting 2 zones to the same working wire at the controller and same at the valve and operate them at different times?
This thread may be of interest to you:
Not sure if it would be a cost saving over running a new wire, but it’s an option:
https://www.amazon.com/Sprinkler-wiring-doubler-device-without/dp/B07FYWHM3L/
Thank you!
I use a Doubler on my system. The initial installer didn’t run enough lines and it was cheaper to install a Doubler than to run more lines to the Rachio. I have a Rachio 3 and it works great. I’ve never used SkyDrop, but I imagine it would be similar.
Thank for the quick response. I was able to successfully use wiresprout, and it worked like a charm. It saved me several hours.
Thank you all for your help!
