I was on chat for a long time and still am confused by all the possible settings.
What does changing from trees to grass to xeriscape actually do? Is it just a shortcut to change the advanced settings?
My theory is that the actual amount of water (frequency & duration) is determined solely by the advanced settings values. The other settings such as zone type, spray head, soil type, etc. are easier for a user to judge and are used to determine the default advanced settings.
When it comes time to calculate the actual watering, only the advanced settings values are used.
For example:
A: select xeriscape and tweak all advanced settings to match what they would have been if you selected trees.
B: select trees and don’t touch the advanced settings
the water frequency & duration would be the same in either case
and they will react to weather changes the same
Is this true?
Thanks…
