Hey so I decided to see how much water I can catch in a can and some small containers
Across the lawn and I was just shy of 1/2” maybe 3/8”
How would this affect the advanced setting on the rachio ?
Right now I have the predetermined sttings
Area 102sq/m
Available water: 0.17mm
Root Deprh: 15.2cm
Allowed depletion: 50%
Efficiency :70%
Crop coefficient: 80%
Nozzle cm/h: 2.54
Take the amount of time you ran your sprinklers and convert over to cm/h and see how close you are to 2.54. I might have taken a stab at the math had you given how long you ran your stations but then again math is hard…lol. And I’m an imperial guy.
@shadow4478, just realized that Nozzle rate in 1 inch per hour so if you ran your zone close to 30 minutes that should be pretty close.
