Soil moisture depletion question, why not 100% after flex watering
Hi franz have a question regarding moisture balance I made some changes to the that one zone that I have on flex daily schedule. the schedule ran for 3 hours shouldn’t the moisture balance be at 100% instead of 53% ?
You will rarely be at 100% after watering, we still need to subtract the evapotranspiration for the day. The only way you would potentially be at 100% is if you manually over water, it rains, or you fill up manually.
